IDK how to fix the (Boot) and (VGA) error codes. I’ve unplugged and plugged everything back in and disconnected and reconnected my GPU. I also took out the GPU and plugged my HDMI directly to the motherboard and still nothing. All the fans and RGB turn on but no post. I checked the ram just in case but nothing. Could you please provide some assistance
https://linustechtips.com/topic/1302354-need-help/
Can you provide a full list of your specs?
The more I learn, the more I realise I don't actually know anything.
Recommendations: Lian Li 205m (sleek, pretty decent airflow for a non-mesh front panel and cheap), i5-10400f (Ryzen 5 3600 performance, 20% cheaper), Arctic P14 PWM fans, Logitech g305.
https://linustechtips.com/topic/1302354-need-help/#findComment-14455677
