Sound card
Go to solution Solved by The Flying Sloth,
Only time you need to modify anything is if you're going from 1x to 8 or 16x, I had to do that and it wasn't fun. You'll be absolutely fine
2 minutes ago, patken007 said:
Can it be possible to connect a pciex1 soundcard  to a pciex16 slot.
yes
Do i need to make some modifications in the BIOS.
no
https://linustechtips.com/topic/1302064-sound-card/#findComment-14453437
You don't have to change anything physically regarding the slots. Just put the card into the slot and ignore the rest of it that's unused. Nothing needs to be changed in the BIOS.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/1302064-sound-card/#findComment-14453455
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1302064-sound-card/#findComment-14453462
