Budget motherboard for running 5600x stock
Solved by Aragorn-,
The cheapest board you can find for sale will run a stock 5600x just fine. Even the junkiest board will run a 65w CPU with no issues. Theres very little to be gained from overclocking ryzen chips either, especially newer ones, their factory boost alogrithm is very good.
I wouldnt bother with B550 if your on a budget either. But B450 might need a bios update so thats something to consider if you dont have access to another chip.
But ofcourse, it really depends how you define "budget motherboard". a 5600x and 1080 arent really budget parts.
