Help me identify this case?
Go to solution Solved by minibois,
2 minutes ago, Kanna said:
I’m looking for a mATX case and I found this and want to know what case it is, if it is mATX and how bad / good it is. All I know is it’s aerocool
I Googled "Aerocool pink case" and found this is called "Aerocool Dead Silence Cube Case".
It's a Micro-ATX case and in terms of quality, it seems like - from glancing at this review - the case is just "fine": https://bit-tech.net/reviews/tech/cases/aerocool-dead-silence-cube-review/1/
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1300872-help-me-identify-this-case/
Do you think I could get a better mATX case for under $50?
Reminder⚠️
I'm not really someone knowledgeable about cases, but it seems decent enough, if not maybe a bit warm because of its closed off design
