Hello everyone, this is my first post in the community.
I build my new PC a month ago with these specs:
  • NZXT H510 white case
  • Ryzen 7 5800X + Noctua D15S chromax black (cooler fits tight, I'm planing to put an additional A12x25 when there's a chromax black version)
  • Crucial Ballistix White 4x8GB @ 3600MHz CL16
  • ASUS Prime X570 Pro (with lights off)
  • Gigabyte SSD M.2 PCIE 4.0 + 2 SSD Crucial BX500 2TB
  • Gigabyte RTX 3080 Eagle (it was the only one I could buy)
  • All Noctua case fans: 2xA14 front, 1xS12A rear and 1xA12x15 top (I can´t put 25mm fans because they collide with the 2x8pin motherboard CPU connectors)
  • Seasonic Focus+ 850W + Cablemod white sleeved cables
The main problem is that the case is an oven. At stock temps the CPU and the GPU run at 50°C. When I play some games, the rear-top part of the case feels really hot.
(I have the last stable bios for my motherboard and the last drivers for the GPU)
So I was looking for a minimalist white case and I found some options:
  • Fractal Design Define 7 Compact Light Tempered Glass (I was also looking at Define 7 but I don't think I put many HDDs)
  • Lian Li PC-O11 Dynamic White
  • Lian Li Lancool 205 White
My main goal is to make my PC cool and quiet.
I would like you to help me chosing a white case with a good airflow, if you have any other recommendation I will appreciate it.
Thank you!
PD: In the image I removed the glass just to take the photo without reflections.
https://linustechtips.com/topic/1300808-looking-for-white-case-recomendations/
  • Lian-Li Lancool II Mesh -- White
  • Phanteks P500(A) -- White
  • Panteks P400(A) -- White
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
The Corsair 275R airflow has a white variant. I have the black one and my temps are great. https://www.corsair.com/us/en/Categories/Products/Cases/Mid-Tower-ATX-Cases/275R-Airflow-Tempered-Glass-Mid-Tower-Gaming-Case/p/CC-9011182-WW
I have the Black one. And my temps are really good during games.
On 1/31/2021 at 4:48 PM, LordRegrad said:
Thank you very much!
I see that the best cases for my PC are the "mesh" type ones.
I will look for the recommended models!
You have a really clean setup! Please make sure you share when you make the move.
My 2020 Upgrade: CPU: Ryzen 5 3600; MB: MSI X570 Tomohawk WiFi; Memory: G.Skill Ripjaws V 32GB 3600 MHz; Case: Lian Li Lancool II Mesh Performance; PSU: Corsair RM550X 80+ Gold; Storage: WD Blue 500GB SSD; Seagate 4TB Compute HDD; Monitor: GIGABYTE G34WQC 34" 144Hz Curved Gaming Monitor, 3440 x 1440 VA 1500R Display
Previous Components Still Using: GPU: MSI GTX 1070 (bought Used); Storage: WD 3TB Green HDD,WD 1TB Black HDD, SanDisk SSD PLUS 240GB
Previous Monitor I want to VESA mount: LG 29UB55-B 29" Ultrawide 1080p 60Hz IPS
I assume "at stock temps" means at idle.
What are the actual temps under load? 50 C kind of warm at idle, but we haven't actually verified there's a problem, "feels hot" is subjective.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
