CPU over temperature error....?
Solved by DeViLzzz,
In the case of broken sensors, I'm guessing that means nothing to worry about?
Well it means that you will not get accurate temps from the BIOS readings and so what I would do now is just use multiple programs to get some readings of your cpu temps in Windows and see if they are similar. If they are then all is fine in my opinion. The only thing safer would be of course getting a proper working board used or new.
