i have pretty high temps
4STY
hello, i need help.I was playing in the bios and found out some settings. one of them was tpu , kind of auto overclock. I activated it and i didnt like the oc. i removed the cmos battery , beacuse it wouldnt reset in the bios. then i reinstalled the battery , re-do the settings in the bios , without tpu , and fired up gta. the temps were higher than normal ( i have water cooler and i was usually getting 60 65 , but now i get 60 - 78 ) and i am scared i messed up something. if you know how to solve the issue , i would be grateful. Thanks
When you reset cmos, everything goes back to normal. Unless you changed something else and forgot that you did. Could it be higher ambient temps than the last time you tested?
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
Just now, DoctorNick said:
When you reset cmos, everything goes back to normal. Could it be higher ambient temps than the last time you tested?
they were lower when i didnt mess with bios oc settings
Then when after reset it should be the same, unless you forgot some setting or the motherboard auto to some different value. did you change fan speed or something?
Last time you where checking temps, was it just after startup? Could it just be higher water temp in the AIO?
FS in Denmark/EU:
i ramped up the fan speed , and the temps are after startup
Ok. Then shutdown and let it sit for 30 min or something and test again
FS in Denmark/EU:
i will try , but someone told me that the water in the cooler had evaporated , is it true?
i think the problem fixed itself,i let the pc in minimal use m and now  i get 55 cpu temp , which for me is good
no. most likely a troll or someone who has no clue.
oh thanks , i thought i was screwed
No. 60-80° would actually still be ok if you're in a game.
