HS60 Microphone not working
Go to solution Solved by QuantumBit,
Turns out the microphone that connects to the headset wasn't pushed in enough. Not sure why it worked on the laptop, maybe it used the laptops audio
Hi
I got a pair of Corsair HS60s yesterday and the mic doesn't seem to work. I've made sure I'm unmuted, i've tried with and without the USB converter it has, but all I can get to work is the speaker portion. The HS60 microphone shows up as an input, but when tested it makes no noise. When I toggle the mic mute, it makes a slight static noise. I plugged it in to a laptop with a dedicated headset port, and it worked there. I'm using an NZXT s340 and a b350 mortar arctic motherboard, and afaik there is no headset port, barring the headphone front panel jack, which I broke.
Basically the HS60's USB adapter doesn't let the mic work (I've tried different ports). Any ideas/work arounds? I've done W10 troubleshoot twice and it has not resolved the issue.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/1298798-hs60-microphone-not-working/
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
