Case fan configuration
By
radosaurus
in Cases and Mods
in Cases and Mods
Solved by minibois,
Of course it depends on what you need, like how warm your components get.
Usually I'd do two fans in the front (top two slot), fan in the back and one fan at the top (back option of the two).
The front back is only needed for a bunch of HDD's, the one above the PSU won't do much good and two fans at the top is usually not needed.
1
toxic_worper ·
Posted in New Builds and Planning8 -
5
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning6
