onboard gpu How to turn-on the onboard graphics at Morter max b450 with 3400G?
1 minute ago, Hridoy Bhuiyan said:I dont have. I lost the manual month ago 聽
You can download the manual from the MSI website, on your motherboard model's page :聽https://www.msi.com/Motherboard/support/B450M-MORTAR-MAX
Click on Manual, and then download the manual in the language you want.聽
聽
The process should be:
Go in bios and select from somewhere to use integrated graphics instead of pci-e graphics card, or (if option exists) to leave both video cards enabled.
Connect monitor to the video outputs on the motherboard IO shield and then start pc...聽
聽
See page 46 in the English PDF :聽https://download.msi.com/archive/mnu_exe/mb/E7B89v1.1.pdf
Set to IGD to start from the Initiate graphics adapter if you want to start with the integrated graphics as primary, and dedicated graphics as secondary
Set Integrated Graphics to Force to enable the integrated graphics even when the dedicated video card has the monitors attached to it.
聽
