Ethernet Adapter Question
Solved by Electronics Wizardy,
1 minute ago, turtlecraft said:Well anyways I was wondering if there is any advantage of geting their adapter versus a thunderbolt or usb-c adapter that would cost half the price.
Normally the integrated nics are better than usb ones, so often a bit faster, and less issues, and lower cpu usage. And you norally have fewer issues with things like pxe boot compared to using usb nics.
But for basic use a usb nic woudl work about the same.
