Smart Home
Oh! ok, back to your question. I only have smart plugs, but I can tell you this much from installing them. Each company makes their own apps (most available from google store or the apple store so you could use a tablet), and so if you want to control them all from the same app, you will need to go with the same brand for everything. I use plugs that work with "Smart Life" app (generic from amazon, don't even have a brand on them) but the app does let you set groups and profiles for them. You should be able to set presets like "away" where the lights are off and the thermostat is lower, or "company" where all the lights are on and the thermostat is warmer, or "in laws" where the thermostat is completely off and the shades are drawn with all the lights off.
