Newer PC Builder* Moving Old PC parts to a new case - Reinstalling Windows
Solved by CommanderAlex,
7 minutes ago, Wet Whoops said:windows key/install is tied to the motherboard but I am unsure.
That is most likely the case here and if you have the Windows key activated on a Microsoft Account with the computer in question, it can be as simple as reauthenticating the hardware is the same before changing your hard drives. You should be able to reuse the same key that was activated with the motherboard before the drive removal and work 100%.
I know on the Microsoft Account, they have an option to reactivate Windows 10 after hardware changes have been made. I will provide a link down below for you on that.
