Dear Pro(s),
Please assist me with my build
Budget: $US1,850 (total)
region: India
My build Idea:
Ryzen 5 3600
Gigabyte b550m ds3h
MSI RTX 3060 Ti
XPG DDR4 3200 mHz (8*2)
Barracuda 2 tb hhd
barracuda ssd sata 1 tb
XPG 240G nvme m.2
corsair cx650
Logitech g213 + G102
LG ultragear 24gl650
ant esport ICE0511MT case
My questions:
will my cpu bottleneck the gpu?
will the PSU be sufficient?
have I made any bad choices?
https://linustechtips.com/topic/1298218-a-noob-needs-help/
6 minutes ago, Ujee said:
Dear Pro(s),
region: India
My build Idea:
Ryzen 5 3600
Gigabyte b550m ds3h
MSI RTX 3060 Ti
Barracuda 2 tb hhd
XPG 240G nvme m.2
corsair cx650
My questions:
The PSU is quite budget oriented. if you can get a higher quality 550W unit, that would be better . (A TXM Gold or CXM for example.)
Other than that it looks good
geometry is hard
b550 > x570
https://linustechtips.com/topic/1298218-a-noob-needs-help/#findComment-14423279
Dear Pro(s),
region: India
My build Idea:
Ryzen 5 3600
Gigabyte b550m ds3h
MSI RTX 3060 Ti
Barracuda 2 tb hhd
XPG 240G nvme m.2
corsair cx650
My questions:
Google says that the GPU will consume at most 200 watts and CPU will consume 65 watts (those numbers are stock. Might go higher if you overclock). It's also important to consider all the rest of the system. 650 is more than enough. A friend of mine has a R5 3600 paired with a 2070 Super (it's quite similar to the 3060 Ti performance wise) and says on his heaviest games his CPU does around 65 - 75 % usage when GPU is maxed.
Like @Downkeysaid it all looks good to me.
https://linustechtips.com/topic/1298218-a-noob-needs-help/#findComment-14423298
Yeah, you don't need 650 watts, it's not bad but you may get a better 550 watts power supply at same price or a few dollars/euro cheaper.
I'd aim for slightly better motherboard, that one is fine for the processor you paired it with, but should you want to upgrade to something more powerful in the future, the motherboard will not be so great.
The CPU won't bottleneck the video card.
https://linustechtips.com/topic/1298218-a-noob-needs-help/#findComment-14423313
