will the dark rock pro 4 fit on this motherboard?
Solved by Analog,
10 minutes ago, wolfff said:dark rock pro 4 cpu cooler
hyper x fury black ram
and a gigabyte b550 aorus pro v2
pcpartpicker says they dont know for sure if the dimensions fit. do yall know it it fits? i dont wanna buy parts that end up not fitting
Should fit just fine. That memory is quite low profile. In their marketing material they have G.Skill Tridents installed, which are considerably taller than the HyperX Fury Black.
