PCI E CABLE Qs
Solved by Ankerson,
Just now, Locutus8of4 said:Why are all pci-e cables a single 8 pin on the PSU side and dual 8 or 6+2 on the GPU side.
Do they makes cables that are just a single 8 pin to 8 pin for GPUs??
Thanks
Yes, they do.
Aftermarket ones like from Cable MOD.
