VRM Temps High?
Go to solution Solved by Mister Woof,
1 minute ago, Apollo Refugio said:
I was gaming on valorant and my VRMs were at 56 C max. is that fine? im not always benchmarking so this is fine right?
more than fine. if you never encounter those scenarios where it's over 100 then don't worry.
some games i play make my CPU/VRM much hotter than others though, so keep an eye out. But if 107 is the highest you ever see in a synthetic test you will never do, it's probably okay.
I am running 5 GHz @ 1.33 volts and my package temperatures are fine, but my VRM temps are quite toasty. I searched online and I'm getting VRM temps are fine at 120 C while others say 85C is max. I have a Gigabyte Z390 UD motherboard, so I'm not sure if this is an issue. Are my VRM temperatures fine (VRM MOS) ?
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/1297084-vrm-temps-high/
That's quite high.
You could try getting some active cooling on the VRM to see if that helps
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1297084-vrm-temps-high/#findComment-14415535
Just now, Mister Woof said:
That's quite high.
What is good active VRM solutions? I cannot find any.
https://linustechtips.com/topic/1297084-vrm-temps-high/#findComment-14415543
Get a 120mm fan and point it at it
Are you using an AIO?
https://linustechtips.com/topic/1297084-vrm-temps-high/#findComment-14415549
28 minutes ago, Apollo Refugio said:
I am using a 360mm AIO.
kinda figured. Most people I see with high VRM temps tend to be on AIOs.
Is yours oriented as front intake? if so, it's probably heating up all the intake air, and blowing a bunch of CPU-heated air over your motherboard/GPU.
Keep in mind the radiator is also acting as resistance for airflow.
If you have rear and top fans, are they oriented as exhaust?
As far as normal operating temperature, the components are designed to run at a maximum of 120 or 125c (forget which), but that doesn't mean you want them to be that hot. They are rated for lifespan and that is at number of hours at xyz temperature. So the hotter your power delivery components are the shorter that lifespan is and increases chances of failures.
https://linustechtips.com/topic/1297084-vrm-temps-high/#findComment-14415635
you can try to mount a 80mm fan on the back of the mobo to blow some air on the VMRs. watch some guides about it.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1297084-vrm-temps-high/#findComment-14415677
I have the 360mm fan as intakes. and i have 3 exhausts fans at the top that are 120mm each. Okay, Thanks!
https://linustechtips.com/topic/1297084-vrm-temps-high/#findComment-14415729
https://linustechtips.com/topic/1297084-vrm-temps-high/#findComment-14416044
https://linustechtips.com/topic/1297084-vrm-temps-high/#findComment-14416048
Although 107c may seem high relative to your CPU temps, it's really not that bad for mosfets. CPU's are exponentially more sensitive than mosfets and can be damaged at about 100c, while mosfets typically can go over 110c without an issue, though you should always seek lower temps. As others have mentioned, getting airflow to your VRM is your best bet.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1297084-vrm-temps-high/#findComment-14416107
