My audio keeps switching polarity from right playing through left ear etc...
Solved by TylerDurden!,
if you are using a laptop or branded desktop, goto the manufactures site, find your product, look under what is usually the support section and find the audio drivers
if it is a motherboard, then do the same at the manufacturers website, download and install your new audio drivers.
When installing it will probably want to reboot after uninstalling, and when it comes back on it "should" automatically reinstall the drivers, give it a moment, if not then just click on the install again
