NVME m.2 can't post when in first slot?
abpc
I just got a 10900kf and a aorus z490 elite AC and whenever I put an SSD in the first port the computer will spin fans and light up but I get no signal nothing at all no noise from the speaker or the you got a problem lights on the board however when I move the SSD too the bottom port it works just fine I'm really not sure what's up and am out of ideas
https://www.amazon.ca/dp/B087GFYBCW/ref=cm_sw_r_cp_apap_NWBvr7WAtAPSB that is the mother board I have
10900kf
Nzxt m22
16gb 3200mhz
5700xt
256gb WD black NVME m.2
650w gold modular PSU
  swapped the PSU before I figured out it was the m.2 with a 700w bronze however the 650w have the 12 pin for the cpu but the 700w doesn't. Ive tested the ram/slots the cooling PSU and all the connections and the GPU the only thing that causes the no post is putting the m.2 in the first shielded m.2 port I would greatly appreciate some help as I'm out of ideas and am waiting to hear back from gigabyte thanks in advance
