best pc Best PC Build?
Solved by SignatureSigner,
You would most lilely want to have a i91900k with a bunch of ram and a beast MOBO. Sli is pointless so go with a 3090. Thats about it. A threadripper has many cores but they are not fast cores. SLI is dead so thats as fast as it gets.
This is all hypothetical of course and you would need rgb everything to get those 1000fps
guaranteed!
Share
Followers
1
