GPU not being detected
Solved by -rascal-,
8 minutes ago, Flaxe said:So I guess GeForce is just being buggy? There's a low chance that my drivers are the issue since I used ddu on all my previous drivers and then installed the latest nvidia drivers.
GT 610 does not have NVENC support.
It does not show up on nVidia's list as NVENC supported GPU, too.
https://developer.nvidia.com/video-encode-and-decode-gpu-support-matrix-new
The "lowest end" card on nVidia's list is the GTX 750, 750 Ti, 950, and 960.
