Corsair TX850M Connecting PCIe to RTX 3080
Solved by .Apex.,
22 hours ago, hauch said:Thanks for quick response. So you are sure, dont want to screw up my 3080 i have been waiting for so long lol? Its a bit confusing why did they write 6+2 PCIe and 4+4 CPU instead of 6+2 PCIe OR 4+4 CPU?
It's because both PCie and EPS (4+4) cables are made up of 12V and Ground, but their arrangement of pins are different, so you need a different cable to make use of each of them, but the port (on the PSU side) stays the same
