Hello guys! 😊
First of all, I'm not sure if Troubleshooting is the correct thread or whatever it's called to submit in, I'm sorry if any moderators have to move my topic.
My PC suddenly wasn't able to POST, but I fixed it. I want to hear what others may think is / was the problem.
So I downloaded ASUS Suite 2, installed it, restarted, started Suite 2, messed up my fan profile, uninstalled Suite 2, restarted - to go into BIOS and redo my fan profile.
When I got into the BIOS, the aspec ratio the BIOS menu is displayed in was changed. But the BIOS menu itself was working perfectly.
I then redid my fan profile and then restarted, and then my PC didn't POST.
I then tried taking out my GPU(startup without GPU and reseat), RAM(tested single stick / reseat), CMOS battery(reseat, to reset CMOS), nothing worked; PC still didn't POST.
Then I tried turning on my PC WITHOUT the CMOS battery installed and then my PC did POST.
Then I turned of my PC, put all hardware back in, also the CMOS battery, and my PC still POST and still works perfectly.
Since then I have restarted multiple times, redone my fan profile in BIOS and so on, everything works perfectly.
But what happened? Does anything know what might have caused this to happen? 😊
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1294774-weird-no-post-problem/
yeah it's probabaly the asus suite application that messed up with the bios...
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
https://linustechtips.com/topic/1294774-weird-no-post-problem/#findComment-14398434
So I was actually kinda lucky that Suite didn't brick my motherboard?
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1294774-weird-no-post-problem/#findComment-14398439
i dont think software can brick your bios that easily to the point it wouldnt work tbh...
My PC
https://linustechtips.com/topic/1294774-weird-no-post-problem/#findComment-14398446
Right, I hear what you say...
Kinda wild though that Suite 2 did all this 😮 😄
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1294774-weird-no-post-problem/#findComment-14398448
