CPU Temps question
Solved by Senzelian,
What really matters is the max temperature, because all you really want is for the CPU not to overheat.
I recommend you stresstest the CPU with a few Cinebench R23 runs and see where you end up. Depending on the max temperature reached, you either increase or lower the fanspeed. Ideally it should be below 80°C in my opinion, but even at 85°C you're not running into any risk. The max temperature for the 3600 is at 95°C.
