Ethernet and 240v power in the same stud
Trilex
As per the title, I live in Australia and had a new house built. I couldn't help notice that the ethernet port was above the wall socket and running in the same stud (see photos). If a a power hungry pc was plug into the socket and the ethernet cable into the pc, wouldn't I have significant EMI for 240v power cable. Shouldn't this be in separate studs?
Orange circle is ethernet
Blue circle is 240v
Technology is NEVER easy :(
Blue circle is 240v
If properly mounted that is not an issue. The wall cables are supposed to be shielded, both power and ethernet. Also your 240V should be grounded as well. I am not sure if you can get 10 Gbit over that line but for standard 1 Gbit you should be fine. I have combo outlets in the office where the cables are even closer together and the connection is good.
