Did you do anything while the update was running? ex: powersurge, internet failure, roomba yanked a cord out of the wall (never had this happen but hey its an example)
please tag me for a response, It's really hard to keep tabs on every thread I reply to. thanks!!
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392787
Just now, nevann_711 said:
It was updating it finished it was restarting and just wouldn’t do it turned it off and then on I think and now i’m here
i kinda blacked out once it didn’t turn back on
what power supply do you have? Mainly asking as some cheapo psu's can be very very very bad at actually doing their job as a power supply
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392804
i do not know all. know is it wasn’t cheap
ok, so are you good with losing all your data? if not, I can't really help you much unless you bring your pc to a data recovery place
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392809
Just now, Radium_Angel said:
See that option for "uninstall updates"?
Do that
yeah do that (holy cow how am I so blind) I literally said to myself "why is there no uninstall updates button?" I guess thats why I have glasses lol
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392818
1 minute ago, nevann_711 said:
i’m perfectly fine with losing all my data
Ok so here's what you want to do. First off, do you have a secondary windows pc available? Also, at least a 4gb flash drive is needed
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392822
yup i got that and that
k here is a link, I dont wanna copy/paste entire tutorial. do this on ur 2ndary pc https://answers.microsoft.com/en-us/windows/forum/windows_10/how-to-create-a-recovery-drive-for-reinstalling/58df9c7d-84de-4652-9952-8bac34abc6c5
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392829
1 minute ago, Dillpickle23422 said:
i have a recovery drive made it won’t give me those options it’s prebuilt and i sent it back to get fixed and now i cant reset anything
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392835
that picture of the advanced options is from booting with a recovery drive
ohh ok, heres another way. https://www.microsoft.com/en-us/software-download/windows10ISO
download that, move it to your flash drive (i believe that it has to be formatted to ntfs to work, not fat32) then put it in the ded pc, go to bios (or you can unplug the storage drive which is either a hdd or an ssd) and change your boot device to the flash drive
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392841
once it boots, you should get a little box telling you what drive you want to reinstall windows to. there should be a format button, when you click the drive, click that, wait, then install it to that drive
lmk if this makes sense or not
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392842
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392851
k so exactly what did you do to do that? as in how or what di dyou click in the troubleshooting menu to do that
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392853
hold the power button once the boot comes up turn it off and then repeat till that pops up
hmm, do you have the usb plugged into the pc?
https://linustechtips.com/topic/1293992-help-urgent/#findComment-14392859
