my two friends have same problem, they have bout 3/4/5 yr old laptop, had battery and charging problems . they gave it for repair and now both their GPU's are not registered in system specs.
does it seem like a software problem or hardware problem? or their GPU's got stolen during repair?
https://linustechtips.com/topic/1293790-laptop-gpu-problem/
country? depends how expensive it is
https://linustechtips.com/topic/1293790-laptop-gpu-problem/#findComment-14391247
Which laptops?
Unless they're using MXM modules you can't "steal" laptop GPUs because they're soldered onto the motherboard.
Said laptops could also not have any discrete graphics.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1293790-laptop-gpu-problem/#findComment-14391278
