I ran there blood red stuff for about 2 years back in 2016ish and had no problems beyond the color change due to the heat affecting red dyes specifically.
Now I just run there Clear Cryofuel as it gives a better look overall I feel and allows for any color scheme you want instead of being locked or very limited.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
8 minutes ago, EmoChipmonk said:
Im looking at Getting EK Cryofuel concentrate. Im leaning toward just getting clear but has anyone had any issues with the pre dyed stuff like gunking up the look at some point? (not talking about the pastels)
I've had their solid white in my system for about 4 months and absolutely no issues so far. I'm about to drain the system to make some changes to my loop in the coming weeks so will get a better idea then.
i have zero plans to use solid stuff.
3 minutes ago, EmoChipmonk said:
Was it the same exact tank for 2 years?
yea, same tank.
Community Standards
"Beast Mode"
I've seen a few reports of the Clear fluid getting a bunch of floaters in it over time.  Probably they didn't put in biocide in a bad batch.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
