it's a new aerocool hive frgb v3 case with a preinstalled rear case fan
it has a molex connector not a 3 pin/4pin pwm that goes directly into the mobo port
i have tried connecting it with the psu's coresponding molex connector but it doesn't start spinning
the same psu cable that have the 3 molex connector have some connector that looks like the one that the 4pin pwm case fans comes with, is it necessary that connector goes into the mobo sys_fan port?
trying to figure out why the fan doesn't work
https://linustechtips.com/topic/1293045-case-fan-doesnt-work/
That extra cable is probably a floppy drive power cable and not needed for the fan.
floppy-berg-mini-molex-58070c473df78cbc2
Make sure there aren't any loose pins in the molex connector and that they're fully extended in the casing.
https://linustechtips.com/topic/1293045-case-fan-doesnt-work/#findComment-14386314
  Reveal hidden contents
i've just tested the psu molex connecter with another old molex fan and it works. it looks like the preinstaled rgb fan was already broken when sent with the case
https://linustechtips.com/topic/1293045-case-fan-doesnt-work/#findComment-14388577
