This is what my setup kinda looks like right now. The reason why there are so many cables is because I unplugged my second monitor. My goal is to have on vertical monitor and one horizontal because one is 25 in and one is 27. Tell me what you guys think my layout should be. Here is an existing photo of what I have.
https://linustechtips.com/topic/1292620-need-help-planning-out-my-setup/
If you're asking for suggestions about monitor layout, I would suggest that you try multiple different layouts and see what feels best to you. If one is a higher refresh rate than the other, use that as your main (horizontal) display.
My Desktop:
CPU: Intel Core i9 9900K
CPU Cooler: Corsair iCUE H100i ELITE CAPELLIX
Motherboard: ASUS ROG Strix Z390-E Gaming (for gamers)
RAM: 4x16 GB G.Skill Trident Z RGB 3200 MHz
GPU: ASUS ROG Strix RTX 2060 Super OC
SSDs: Samsung 980 Pro (1TB), 870 Evo (1 TB), 860 Evo (1 TB), 860 Evo (500 GB)
HDD: Seagate Barracuda Compute (8 TB)
PSU: Corsair RMx 1000W w/ CableMod cables
OS: Windows 10 Pro
Case: Corsair SPEC-06 RGB
Monitors: LG 34GL750-B, Samsung CF591
Pegasus (Server):
CPU: AMD EPYC Rome 7282
CPU Cooler: Noctua NH-U12S TR4-SP3
Motherboard: SuperMicro H12SSL-CT
RAM: 4x16 GB Samsung 3200 MHz DDR4 ECC (M393A2K40DB3-CWE)
GPU: PNY NVIDIA Quadro P2200
SSDs: Samsung 970 Evo (1 TB), WD Red SA500 (1 TB), SanDisk Ultra 3D (500 GB)
HDDs: 5x Seagate IronWolf NAS 8TB
HBA:  Avago LSI 9211-8i
PSU: Athena Power AP-RRPS2K20
OS: unRAID
Chassis: Rosewill RSV-L4500
Chassis Fans: 6x Noctua F12 PWM, 2x Noctua A8 PWM
My main monitor is 144hz which is the middle. I’m looking for a more symmetrical look. There is no mounting so I’m kinda relying on books and some other stuff to hold it up, any tips on holding it up without  a stand?
If they're vesa compatible, AmazonBasics has some cheap stands. Other than that, I have no ideas
My Desktop:
OS: Windows 10 Pro
Pegasus (Server):
OS: unRAID
