Sounds about right
https://linustechtips.com/topic/1292618-cinebench-temps/#findComment-14382149
Appears to be normal. Nothing wrong there. CPU benchmarks tend to make them run hotter than average use in games if your worried about that.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1292618-cinebench-temps/#findComment-14382155
Yeah cp2077 is about 61c when playing in 1440p so thats alright.
Just wanted to check as I recently changed my mobo and it included repasting etc. Got a tiny bit of paste stuck on the side of the cooler but if anything the temps are lower than they were before changing mobo
https://linustechtips.com/topic/1292618-cinebench-temps/#findComment-14382178
Those temps sound very good. Overall, I wouldn't worry about your temps unless they start to rise/overheat/thermal throttle.
https://linustechtips.com/topic/1292618-cinebench-temps/#findComment-14382198
OK thanks :)
This is where I got some excess paste, I tried my best to get it off but I couldn't...
https://linustechtips.com/topic/1292618-cinebench-temps/#findComment-14382235
1 minute ago, venomx said:
OK thanks :)
~Snipped photo~
That should be fine as long as the paste is not runny/watery and could seep onto the motherboard. If the paste is nonconductive, I would even worry about it less. I personally try to remove all the thermal paste as I think its dirty looking like what you see in Gamers Nexus videos on some CPUs.
https://linustechtips.com/topic/1292618-cinebench-temps/#findComment-14382246
Yeah it wasn't runny at all, was a sticky sort of paste, It's also non conductive yes.
https://linustechtips.com/topic/1292618-cinebench-temps/#findComment-14382258
