i have 16gb of ripjaws v 3200mhz i had that kit for a very long time and now i decided to buy another 16gb of the same kit and when i installed it in my pc the second i get to the windows loading screen it gives me the "youre pc ran into a problem"
i dont know if the memory kit is faulty or its something with my pc
ryzen 5 2600x
gigabyte b450m ds3h
rx 570 nitro
https://linustechtips.com/topic/1292496-ram-issue-please-help/
1 minute ago, Marhier said:
Have you tried each memory stick individually?
Also, have you installed them next to each other, or have you spaced them out and in the correct configuration in accordance with your motherboard spec?
i have 4 slots and i allready had 2 that were spaced so i filled the rest
https://linustechtips.com/topic/1292496-ram-issue-please-help/#findComment-14381264
