So I built a Ryzen based computer just recently. It ended up not posting and the MOBO had a CPU error debug LED on so after some online digging I decided to try reseating it. In hindsight I must have put on too much thermal paste because when I removed the heatsink the CPU came out with it. After inspecting the CPU i noticed it had bent pins (two central pins on either side of the centre, ones that I would expect wouldn't bend on removal but also would possibly cause it not to seat properly but I didn't notice any seating problems). Luckily I brought a warranty on my basket so it was covered for accidental damage so I returned it. Now I'm wondering whether those pins bent as a result of DOA, Insertion or removal. What are the chances that when removed without first unlocking the retention arm (with the heatsink) that pins would have bent? I want to know as it could be a motherboard error that was also either DOA or broken whilst building (Im not an experienced system builder, I didn't wear an antistatic wrist band however I grounded myself often on a radiator pipe and was wearing shoes I don't remember any static shocks) because then I can get ready to remove it and send it back as well. To note as well, I had to update the BIOS using MSI's Flash BIOS feature as, to my knowledge, x570 chipsets do not natively support Zen3. If20210109_010129.thumb.jpg.8957e85742ed6daa23c5b9e04aecc0d2.jpg this install failed for whatever reason, that would also 20210109_012044.thumb.jpg.e9ffe3c9924fc332816f005a1e4f3750.jpgcause a CPU error and stop it from posting. Is there also a chance of this happening?
https://linustechtips.com/topic/1292394-bent-ryzen-pins/
It's not actually that uncommon for the CPU to come out with a heatsink. The paste can make such a good seal on there, and if the heatsink doesn't have room to twist, the negative pressure will take the CPU with it. That being said, that alone is almost never a big deal.
The bent pins though, at this point you might as well try and bend them back because it won't work as is, and it won't work if the bent pins snapped off, so at this point you have nothing to lose.
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
https://linustechtips.com/topic/1292394-bent-ryzen-pins/#findComment-14380756
6 minutes ago, Halster said:
So I built a Ryzen based computer just recently. It ended up not posting and the MOBO had a CPU error debug LED on so after some online digging I decided to try reseating it. In hindsight I must have put on too much thermal paste because when I removed the heatsink the CPU came out with it. After inspecting the CPU i noticed it had bent pins (two central pins on either side of the centre, ones that I would expect wouldn't bend on removal but also would possibly cause it not to seat properly but I didn't notice any seating problems). Luckily I brought a warranty on my basket so it was covered for accidental damage so I returned it. Now I'm wondering whether those pins bent as a result of DOA, Insertion or removal. What are the chances that when removed without first unlocking the retention arm (with the heatsink) that pins would have bent? I want to know as it could be a motherboard error that was also either DOA or broken whilst building (Im not an experienced system builder, I didn't wear an antistatic wrist band however I grounded myself often on a radiator pipe and was wearing shoes I don't remember any static shocks) because then I can get ready to remove it and send it back as well. To note as well, I had to update the BIOS using MSI's Flash BIOS feature as, to my knowledge, x570 chipsets do not natively support Zen3. If20210109_010129.thumb.jpg.8957e85742ed6daa23c5b9e04aecc0d2.jpg this install failed for whatever reason, that would also cause a CPU error and stop it from posting. Is there also a chance of this happening?
You are assuming that your X-570 won't support Ryzen 3. If it's a recent Asus Mobo, it will work with Zen 3 without bios patching.
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
https://linustechtips.com/topic/1292394-bent-ryzen-pins/#findComment-14380771
As I said, Ive already sent it back, my question was what the likelihood was that those bent pins are a result of the action of me pulling it out with the heatsink, or DOA? Just noting the location of said bent pins in my mind, is odd for being a result of this action.
https://linustechtips.com/topic/1292394-bent-ryzen-pins/#findComment-14381631
