What are your temps under full load?
Also, HWMonitor tends to be quite inaccurate, especially with Ryzen systems. I'd suggest you use HWiNFO64 instead.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1292112-ryzen-7-5800x-temps/#findComment-14378881
Just now, Driver95 said:
@Mateyyy
I havent tested full load yet.
I'm using HWiNFO64.
Yeah, for some reason I thought that was HWMonitor, lol.
Idle temps don't really tell a whole lot, other than cases where there's a bad cooler mount for instance (where you'd see temperatures over 80C), hence why you should run a full load on the CPU. Even something like Cinebench R20/R23 would work.
https://linustechtips.com/topic/1292112-ryzen-7-5800x-temps/#findComment-14378890
