I'm doing a build for a friend. I'm waiting to order parts until after ces because I'm hoping to see cpu and gpu prices fall a bit after we see new announcements but for the next 40 or so hours the motherboard is $40 off so if you think I'll save more bu not waiting let me know. I'm hoping to cut the cost a but. As of now I'm looking at just over $770 even though I was targeting 600. If possible I'd really like to get the cost below 700 dollars and im not opposed to getting a used cpu and gpu.
The build will be in this off brand Amazon case
As of now I'm thinking to use a core i3 10100, 16 gigs ddr4 crucial ballistics 3200, these amazon rgb fans, an adata 480 gig SATA ssd, an asrock z490 pro, a gtx 1660, and evga 650 n1
Budget ($600-700):
Country: us
Games: Minecraft with mods, the forest, rust, apex, and some others.
https://linustechtips.com/topic/1292069-new-build-please-help/
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1292069-new-build-please-help/#findComment-14378644
https://linustechtips.com/topic/1292069-new-build-please-help/#findComment-14378668
https://linustechtips.com/topic/1292069-new-build-please-help/#findComment-14378712
I talked to the friend and he decided to up the budget. We went with a ryzen 5 3600, a gigabyte a520i, (last minute opted for the 10100 and a msi b450m pro), evga 650 n1, crucial balistix 3200, and an adata su635. We will pick up the gpu when possible.
https://linustechtips.com/topic/1292069-new-build-please-help/#findComment-14379532
Are you sure you got it right? That MSI B450M Pro is an AMD socket board, while the i3-10100 is an intel processor.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/1292069-new-build-please-help/#findComment-14379594
The adata su635 is a dramless ssd, will affect endurance of the ssd
https://linustechtips.com/topic/1292069-new-build-please-help/#findComment-14380601
