Hello, im recently upgrading my old Computer from this setup:
Asus prime B360M-K
I3 8100 intel core
1060 Phoenix ASUS (3Gb)
8 Gb RAM 2400MHz
corsair vs550 power supply
to this setup is this good or not will the things work Together?
New setup:
Asus prime B360M-K ( same mobo)
Intel core i7-9700k
Asus GTX 2070 8(GB) dual
16 Gb Ram 2666MHz
corsair vs 550 power supply (same)
plssss help me!!!
https://linustechtips.com/topic/1291973-new-build-plsss-help/
Might help if you actually fill out the form you added to your post.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1291973-new-build-plsss-help/#findComment-14378022
There is little point in putting an unlocked cpu on a B360 motherboard. It will work (you may need to update the bios first), but it cannot be overclocked. The i7-9700 might save you a bit.
Without knowing how the system will be used and how much the upgrade would cost, it's not really possible to judge how good the new system would be.
https://linustechtips.com/topic/1291973-new-build-plsss-help/#findComment-14378130
You will benefit more when using an Intel Z-series board with a K-SKU unlocked processor as Intel only allows you to overclock their processors on Z/X series motherboards.
1 hour ago, Jayminja said:
Old:   8  Gb RAM 2400MHz
New: 16 Gb RAM 2666MHz
If you're spending money on a new 2x8GB kit, that is pretty worthless imo. If you're staying with the same motherboard, use a locked processor and that RAM kit.
You're pairing this with a 2070? That power supply is good for office builds.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1291973-new-build-plsss-help/#findComment-14378173
What World you recommend power supply??
https://linustechtips.com/topic/1291973-new-build-plsss-help/#findComment-14379042
Corsair RM750x.
https://linustechtips.com/topic/1291973-new-build-plsss-help/#findComment-14379049
