URGENT: Pc will not boot
Solved by jaslion,
Just now, NicekillBG said:It turns on without the rgb lights, then the rgb lights turn on and the fans go max speed after that it goes to phase one, slow spinning and no lighting
Sounds like either boot looping or just straight up boot failur
1 minute ago, NicekillBG said:Have not touched the bios as it is a b550 and I thought it will run, should I q flash it?
Not many boards are running a new enough bios for ryzen 5000 cpu's so IF it can do a bios update without the cpu (follow the instructions from gigabyte VERY CLEARLY) then do so.
