How does thermal paste work?
Go to solution Solved by Moonzy,
3 minutes ago, richodude said:
what about the non-conductive thermal paste?
when they say non-conductive, they mean electrically
Why does the paste work so well compared to other liquids like they did in that one ltt video?
probably because of vicousity, and conformity
and thermal conductivity
I get it's supposed to help with thermals but what about the non-conductive thermal paste? Isn't the whole point so that the paste fills in the gap and efficiently conducts heat to the cooler? Why does the paste work so well compared to other liquids like they did in that one ltt video?
OUTDATED JAN 2021 ===========> Check out my pc building guide! might be useful tho
It's great for planning new builds, getting a reference on where to start, or seeing what you need to play what games.
It also shows what I recommend for upgrading your stuff!
cpu - ryzen 5 3600
gpu - gtx 1070
ram - (2x8) 3200mhz
ssd - 970 evo plus 500gb
ssd2 - 860 qvo 1tb
mobo - asrock b450m hdv r4.0
psu - evga b5 550w bronze
https://linustechtips.com/topic/1291157-how-does-thermal-paste-work/
-sigh- feeling like I'm being too negative lately
1 minute ago, SSI Jake said:
Thermal paste works as a thermal conductor from one surface to another. In the case of a CPU the thermal paste transfers heat from the CPU to the fan heat sync to allow for cooling.
Thanks! one more thing. what about thermal pads? same thing different story? Does them being thicc bois make them worse?
cpu - ryzen 5 3600
gpu - gtx 1070
ram - (2x8) 3200mhz
ssd2 - 860 qvo 1tb
depends on surface smoothness and height (mainly height)
but... thicker is always worse given the same thermal conductivity, so paste is normally better if you can get good contacts
pads are used because of uneven surface and surface height (like 1 vram chip to another), so pad allows some leeway and still do an okay job at conducting heat
using thermal pad on a die instead of paste is a bad idea
Thermal paste is more conductive than a pad, you will get better performance from a paste, however with some configurations and/or hardware pads are used with decent success.
