Budget (including currency): as low as possible
Country: UK
Games, programs or workloads that it will be used for: Mainly fps shooters
Hey, Im going to build my first PC in the near future but I'm a complete novice when it comes to stuff like this. I've managed to get my hands on a AMD Ryzen 5 5600X Processor and a RTX 3060 Ti GPU but don't know what grade all the other components will need to be. I want to build my PC as cheaply as possible but want to maximise the CPU and GPU at the same time. I've been looking online at similar builds but they all vary in the price spent on ram and motherboards etc. Also been seeing various amount of fans in different builds so have no idea what sort of cooling system will be sufficient.
Thanks if you took the time to read this or can give me any advice
https://linustechtips.com/topic/1290777-help-me-build-my-first-pc/
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
Also some motherboards need a bios update for the b550 boards. you can ask the seller to bios update it or ask AMd for their bios update kit.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
Motherboard: Just get a cheap B550 or try to get a B450 and borrow a 2nd gen Ryzen chip to do a BIOS update. For the most part, the main difference between motherboards is looks, overclocking support (which shouldn't be a concern on a tight budget, especially for Ryzen), and the amount of I/O. Get something with enough USBs for your use case and you should be fine.
Cooler: Just use the stock cooler. It'll be fine if you aren't overclocking. If you want to upgrade down the road, it would be a good option, but it isn't something necessary at the beginning.
RAM: Get a kit of 3200MHz CL16
PSU: 600w that's relatively high on the PSU tier list
Case: Cheapest one you think looks nice that supports ATX motherboards. You'll (probably) be fine
15 minutes ago, Prodigy_Smit said:
Thanks for the response really do appreciate it
Thanks for the list, looks a great price. Would you happen to know if any of them retailers listed on PCpartpicker would do the bios update for the b550 if i contacted them about it? Cheers
Thanks for the response, I've got a much better idea of what I need now.
Oh don't worry about it since the B550-a pro has bios flashback all you need is a USB drive and a computer to copy the bios onto the usb.
Desktop :
Laptop :
Just now, Prodigy_Smit said:
Uhhh one sec that PSU is not great get this one instea
both are tier B.
both have LLC and are DC-DC
Just now, SavageNeo said:
both are tier B.
Oh I thought the Adata was a c teir. Thanks for the info.
Desktop :
Laptop :
oh. I thought that you talked about the core GC?
the core reacotr is tier A blued unit actually.
Damn. I removed the second build from the thread.
Desktop :
Laptop :
