I got a new wireless mouse for christmas why are links so long and it lags when in wireless mode. I can describe this as it feels like the polling rate jumps down to about 5hz for a few seconds every once in awhile. I've never had this happen in wired mode.
Physical obstacles are my desk ~2feet of it. I moved my computer so that just my pull-out tray was in the way and still the same thing.
I went on the ipictek website to download the mouse driver but when I look in dev mgr it is labeled as "HID-compliant device" which is alongside my old mouse "Razer Cynosa Chroma" (curiously enough when i uninstall this device and scan for hardware changes it comes back)
How can I prevent this lagging? The only reason I got this mouse was because its wireless
OUTDATED JAN 2021 ===========> Check out my pc building guide! might be useful tho
It's great for planning new builds, getting a reference on where to start, or seeing what you need to play what games.
It also shows what I recommend for upgrading your stuff!
cpu - ryzen 5 3600
gpu - gtx 1070
ram - (2x8) 3200mhz
ssd - 970 evo plus 500gb
ssd2 - 860 qvo 1tb
mobo - asrock b450m hdv r4.0
psu - evga b5 550w bronze
https://linustechtips.com/topic/1289278-wireless-mouse-lagging/
It's probably 95% due to it being a cheap off-brand mouse. Is the lagging a lost-connection type or a crap latency type? Have you tried it in another computer and if so is the issue still present?
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/1289278-wireless-mouse-lagging/#findComment-14358376
Is 25 dollars really too cheap for a mouse? I wanted something not shit like those 10 dollar gaming mouses but something slightly more reasonable than the 150 dollar razer mouse that looked nice. The latency is still the same when it lags, its like when your game drops to 10 fps for a few seconds, thats what my mouse feels like except everything else is fine.
cpu - ryzen 5 3600
gpu - gtx 1070
ram - (2x8) 3200mhz
ssd2 - 860 qvo 1tb
https://linustechtips.com/topic/1289278-wireless-mouse-lagging/#findComment-14358421
It's on the cheap side which is fine, the bigger issue is it being an off-brand one of a million type of companies. I mean, the "about us" section on the website goes nowhere. An even cheaper microsoft wireless mouse might have been a better choice in terms of reliability. Off-brand "cheap" products usually have worse quality control.
https://linustechtips.com/topic/1289278-wireless-mouse-lagging/#findComment-14358456
