Will there be any cpu bottlenecking happening if I paired my Ryzen 5 2600 with RTX 3060 Ti?
Solved by PenguinMaster,
3 minutes ago, KLD said:I've seen youtube videos online where the combination gives you a CPU usage higher than the GPU's and when I ask forums or use the "Bottleneck Calculator" I'm getting various responses... Some says its fine and others just show how bad the cpu bottleneck is... pls help
Oops, I was thinking about the 3600 not the 2600. I think that you will have some problems with the 2600. I would recommend selling that and getting at least a 3600 if your motherboard supports it for that GPU. Otherwise, maybe when RTX 20 series are a reasonable price again, consider picking up a 2060.
