We all know that each memory bus has an amount of memory which has a native support, right?
Well I was wondering if the Memory bit x 10 would equal the max supported memory on the bus.
Example:
192-Bit
192 x 10 = 1920 MB of supported memory
384-Bit
384 x 10 = 3840MB of max supported memory.
Does this actually work or am I just imagining things?
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/128866-memory-bus-guide-on-max/
Example:
192-Bit
384-Bit
256bit x 10 = 2560MB, yet you can have 4GB on that bus.
I budget build well. Want to learn? PM me if you want advice.
https://linustechtips.com/topic/128866-memory-bus-guide-on-max/#findComment-1714519
But the question is, is the equation theoretically correct to the application I place on it?
https://linustechtips.com/topic/128866-memory-bus-guide-on-max/#findComment-1714523
No because you're saying 2560MB would be the max on a 256bit bus, but it isnt.
https://linustechtips.com/topic/128866-memory-bus-guide-on-max/#findComment-1714548
You can have 4GB on a 128 bus(EVGA GT 640), I think what Bluejay means is what is usable by the card under the best case scenario.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/128866-memory-bus-guide-on-max/#findComment-1714557
To be installed, no it's not the max physically. However, the bus can only support so much natively.
https://linustechtips.com/topic/128866-memory-bus-guide-on-max/#findComment-1714560
OOOOHHHHH. Then yes, it seems to be that way.
https://linustechtips.com/topic/128866-memory-bus-guide-on-max/#findComment-1714572
Its like pumping a card with so much more memory than it can handle over the bus... is his question yes?
Is it a waste as it cannot fully utilize the excess vram. yes?
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/128866-memory-bus-guide-on-max/#findComment-1714602
