compatible?? Is my motherboard compatible with my CPU?
Solved by 8tg,
6 minutes ago, Hyper_sg said:So does that’s mean that any Intel 8th or 9th gen processor that supports the socket but has a letter at the end isn’t compatible?
The F just means it has no integrated graphics. The K means it can be overclocked.
Both will work fine on B365, you can’t overclock the K processor but it’ll operate normally otherwise.
Featured Topics
Nov845 ·
Sanderdrejer ·
Posted in Troubleshooting2 -
smore09 ·
Posted in Graphics Cards2 -
VL_Hermes ·
Posted in Laptops and Pre-Built Systems3 -
9
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
