I am looking at the 1TB 970 EVO ($139) and the EVO Plus ($149) on Newegg. I have looked at the specs of both and it seems that the only difference is the read write speed. Are there any other differences and is it worth a 10 dollars price difference? What do you guys think?
OS: Microsoft Windows 10 Pro, Motherboard: ASUS Crosshair VI Hero, CPU: AMD Ryzen 5 3600, Heat Sink: AMD Wraith Prism RGB, Video Card: FTW GeForce RTX 3080, Memory: 4 x G. Skill Trident Z RGB Royal 8GB (total 32GB), Power Supply: Thermaltake Tough Power Grand RGB750W, MonitorAOC Q32G1WG4, HD: 2 x Samsung EVO 850 and 4 x Seagate 2TB ST2000DL 003-9VT166 SATA HD, Keyboard: G. Skill RipJaws KM780R RGB Mechanical Keyboard, Mouse: Logitech G903 Wireless, Network Adaptor: D-Link DWA-192 AC1900 Wi-Fi USB 3.0
https://linustechtips.com/topic/1288368-970-evo-or-evo-plus/
Not worth the extra cost unless you need it for workstation use, in which case the Pro would be even better.
https://linustechtips.com/topic/1288368-970-evo-or-evo-plus/#findComment-14351182
The Pro is too much for my budget, as for the use, Only gaming.
https://linustechtips.com/topic/1288368-970-evo-or-evo-plus/#findComment-14351185
43 minutes ago, Applefreak said:
The base EVO is fine then.
30 minutes ago, Senzelian said:
Pay 7% more to get 40% higher write performance? I'd pick the plus to be honest.
Now I am so confused. Do I get the EVO or pay the 10 bucks more and get the Plug. Maybe I should flip a coin. Heads The EVO, Tails the Plus.
https://linustechtips.com/topic/1288368-970-evo-or-evo-plus/#findComment-14351268
FlipSimu.com came up tails so Plus it is. Thanks guys.
https://linustechtips.com/topic/1288368-970-evo-or-evo-plus/#findComment-14351269
