Just today I got my new Ryzen 5 3600 for my system. I was excited because my previous CPU seemed to bottleneck my rtx 2070, and it seemed I was right. I was getting more utilization and some games were up to 30fps faster, but then I looked at the cpu temps. When I was playing Far Cry 5 I was getting anywhere from 30 to 60 percent load on my cpu, yet my temps were at 80c, sometime even going above that. I found this odd so I downloaded prime 95 to do a stress test and monitor the cpu. After about 20 seconds of the test my cpu peaked at 90c. I know there was thermal paste since I used the stock cooler and I can see that the fan is moving, yet the temps I am getting are absolutely insane. I am looking at Ryzen master and my idle temp is 50c, but at random times I see it jump up to 60 then fall back down. Does anyone know what the problem could be?
Specs:
CPU: Ryzen 5 3600
Motherboard: B450 Tomahawk Max
GPU: RTX 2070
RAM: 16GB DDR4
https://linustechtips.com/topic/1287679-problems-with-cpu-temps/
A cheap cooler like the Hyper 212 will do wonders, People get 60C max even with Prime95
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
6 hours ago, Radium_Angel said:
Get a better cooler.
I'm thinking about it but still how can I be certain something is not up with the cpu? The max temp is like 95c but I've never seen it go this high, stock cooler or not, especially when it is at 40 to 70 percent load.
You can't, until you replace the cooler (and associated thermal paste) with something better.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Wraith stealth post-nerf sucks.
But it should be fine for most gaming situations, and 80c isn't the end of the world.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
Alright I got a better cooler but the temps haven't lowered all that much. For sure there has been some improvement but I'm still getting like 50c idle and anywhere from 70 to 80c under load. I think it might be an issue with the voltage but I can't say for certain. The peak current limit tends to spike a lot and sometime goes red which seems to be the cause of a lot of heat. For now though I think I will stick with it since as long as its below 80 I should be fine.
35 minutes ago, Radium_Angel said:
I have not heard about this, explain please?
Original Stealth had a copper core
the ones that shippied with 2nd gen (or maybe 3rd?) are all aluminum
er edit: guess it was just the spire
