Setting up an EGPU
Go to solution Solved by Kilrah,
After.
Recently, I have purchased an eGPU. Yesterday, I put it together with a msi 2060 super. The ePGU is a Mantiz Saturn pro v2. When I plug it in, windows installs some drivers on its own. Do I install nvidia drivers or am I fine? Because when I opened up nvidia control panel it said that a non nvidia gpu was installed.
https://linustechtips.com/topic/1287609-setting-up-an-egpu/
You should install the Nvidia drivers by yourself.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1287609-setting-up-an-egpu/#findComment-14345359
After.
F@H
GPD Win 2
https://linustechtips.com/topic/1287609-setting-up-an-egpu/#findComment-14345429
