Hey guys. I recently installed Ubuntu 13.04 and love every aspect of it except one. :( My Roland quad capture doesn't work.
I still have windows but I would like to use linux for the day to day things as it is much cleaner. So I was wondering what sound cards people could recommend that will work with Ubuntu. I would prefer it to have a front panel connector (not a biggy) and it must work with a mic for skype and so forth.
I have looked into the ASUS Xonar DG but it seems as though the mic port will not work with linux.
Thanks for any help people can give I appreciate it massively. :D
The first step to insanity is believing in your sanity.
https://linustechtips.com/topic/12875-good-sound-cards-for-linux/
I've tried Ubuntu 12.04 with a Xonar DG and everything works perfectly. Why dont you just use the onboard audio with Ubuntu?
Mobo: Asus Maximus Impact VI Processor: Intel 4690K @ 4.4Ghz 1.22Vlts Memory: 2x8 GB DDR3 1866Mhz GSkill Sniper
VGA: Sapphire HD 7970 3GB OC Audio: Asus Impact Supreme FX SSD: Mushkin Chronos 120GB HDD: WD Black 500GB
Power Supply: Coolermaster V650 Semi Modular Case: Bitfenix Prodigy Cooling: Corsair H100i
https://linustechtips.com/topic/12875-good-sound-cards-for-linux/#findComment-137898
I don't care what everyone else hears so I use onboard for mic and a usb dac.
if you want an all-in-one thing, I'd go with an emu-0404 or 0202
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/12875-good-sound-cards-for-linux/#findComment-137919
Hmm, how interesting. The website for the audio drivers says that the mic wont work. I don't wan't to use onboard because it sounds like rubbish.
I already have an external DAC that works with windows but not with linux. There is no fix :(
My DAC / Audio interface is a roland quad capture.
https://linustechtips.com/topic/12875-good-sound-cards-for-linux/#findComment-139327
do you have pulse audio volume control?
it's pavucontrol in synaptic.
it's how I change the default audio device.
https://linustechtips.com/topic/12875-good-sound-cards-for-linux/#findComment-139465
I do not, I will look into it today, thanks.
https://linustechtips.com/topic/12875-good-sound-cards-for-linux/#findComment-139485
