Hi!
So, i got an asus rx470 4gb mining edition card, it has been flashed to rx570 and seems to work just fine for gaming, getting reasonable fps and no bugs, but there is one thing i don't understand fully (i am kind of new when it comes to stuff like flashing bioses ect.)
This card works on ddr4 system, but not in any ddr3 systems i threw it in, i just could not get output from the card.
Is it due different bios or is it something that can't be changed?
Any help and information is much appreciated.
https://linustechtips.com/topic/1287446-flashed-mining-card/
What is the motherboard in question ?
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1287446-flashed-mining-card/#findComment-14344866
can you revert back to the old bios if you flash the beta one in ?
I9 10850K
MSI Z490 Tomahawk
https://linustechtips.com/topic/1287446-flashed-mining-card/#findComment-14348361
then why not try the beta bios and see if it's working fine
I9 10850K
MSI Z490 Tomahawk
https://linustechtips.com/topic/1287446-flashed-mining-card/#findComment-14354300
