Budget:  max I want on cpu is 200 and Mac I want to spend on a gpu is also around 200
Country:  USA
Games, programs or workloads that it will be used for:  games like COD and GTA and I will be doing some coding and homework on it too
Other details: right now I have a ryzen 5 2400g as-well as a EVGA 1050 SC. I want to upgrade both my CPU and GPU so I don’t have to worry about it later on. I have a 500 watt psu and don’t know if that will be a problem. i was also planning on getting a new case and an aio over the years but those aren’t needed right now.
https://linustechtips.com/topic/1287055-pc-upgrade-help/
What motherboard do you have?
Just now, Biraj Lamsal said:
Can you tell what is your budget
$400 total.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1287055-pc-upgrade-help/#findComment-14341611
3 hours ago, Mohammad Saleh said:
can you make it more clear
So I was planning to get a new GPU but from what people have told me is that if I were to get a new gpu I would most likely need to upgrade my cpu so i don't bottleneck the gpu. Idk if that's true tho
https://linustechtips.com/topic/1287055-pc-upgrade-help/#findComment-14342239
3 hours ago, Biraj Lamsal said:
you already have decent rig. Why you need another 400$.
Do you want it for dual pc streaming setup?
I was just gonna get a new GPU but people have told me that I would most likely need to also upgrade my CPU so i dont bottleneck it
https://linustechtips.com/topic/1287055-pc-upgrade-help/#findComment-14342245
just wait now is one of the worst times to buy cpus and graphics cards just wait till jan till we see the rtx 3050 and rtx 3060 non ti verson those will fit in your budget
https://linustechtips.com/topic/1287055-pc-upgrade-help/#findComment-14344111
Ok thanks. I didn’t know that there will be more gpu’s dropping anytime soon
https://linustechtips.com/topic/1287055-pc-upgrade-help/#findComment-14344751
If I were to get the 3050 so you think I would need to upgrade my cpu too? Or would I be fine
https://linustechtips.com/topic/1287055-pc-upgrade-help/#findComment-14344757
4 minutes ago, GeneralGusher said:
I would but I don’t have any good experience with used pc parts especially gpu’s
Honestly, I would get a used 1070 or 1080. If you do get scammed eBay has a good buyer protection.
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 5 3600 3.6 GHz 6-Core Processor $199.99 @ Best Buy
Video Card Asus GeForce GTX 1070 8 GB STRIX Video Card $200.00
  Prices include shipping, taxes, rebates, and discounts
  Total $399.99
  Generated by PCPartPicker 2020-12-30 09:13 EST-0500
If you wait about a couple months then you could probably get a 3050 and a 3600/1600AF
geometry is hard
b550 > x570
https://linustechtips.com/topic/1287055-pc-upgrade-help/#findComment-14344771
