PSU watt checking for build
Solved by Boomer_Claus,
Hi. I can try and answer for you.
https://linustechtips.com/topic/1116640-psucultists-psu-tier-list/
A 750w tier A unit for this list would probably be enough. You might want an 850w for more headroom.
Most Gigabyte PSUs are not very good and the one you listed is considered the worst at tier E so I would avoid it. Try to return it.
